Is there a way I can edit an STL after importing it?
I am trying to cut the sides of an STL I imported, but it won't let me. Does Onshape allow STL's to be edited? Or how can I edit this piece?
  • philip_thomas
    edited January 2018 Answer ✓
    For someone whose 'dislike' of STL is so strong, you would think i would have had this response ready to paste from my clipboard! :)
    (Am I the last person using the pluperfect tense in posts?)
    I am piling on here @meghan_frederick, not to try to beat you with a stick, but for others that will find this thread when searching.
    STL is an end state. There is no intelligence and it is a 'low resolution' (faceted) representation of a b-rep ('boundary representation - aka, solid model).
    It is the LAST thing that you want to be editing. It's like making a photocopy of a book page and then saying you want to use that to edit the text  - Its not going to happen.
    I use STL files - we have 3D printers here at the office and i have one at home (you know, like all engineers), but i edit the b-rep to make changes and then publish the STL.
    There is a bona fide need to manipulate STL when reverse engineering (as a last resort) and i accept that need (although we dont do that).
    If you have downloaded something from Thingiverse (all are STL), i would suggest alternative repositories of free content.
    The Onshape public documents are great resource as is GrabCad.
    If you genuinely need to edit STL files, the only free STL editor that i know of is MeshMixer.
    Like most Autodesk software, it's cheap but you definitely get what you pay for! ;)
    At the professional level, the gold standard is Geomagic Raindrop (starting at $36,000)
    I hope this helps - Philip.
    Philip Thomas - Onshape
  • philip_thomas
  • owen_sparks
    Hi, @philip_thomas, great explanation.
    Please will you add this "paste answer button" alongside the other two?
    Cheers,
    Owen S.
    HWM-Water Ltd
  • meghan_frederick
    meghan_frederick Member Posts: 8 EDU
    (I am the last person using the pluperfect tense in posts?)
    It is the LAST thing that you want to be editing. It's like making a photocopy of a book page and then saying you want to use that to edit the text in a book using the photocopy - Its not going to happen.
    I also found that 3D Builder on Window computers work aswell.
  • GWS50
    GWS50 Member Posts: 537 PRO
    edited December 2020
    This is a fantastic Featurescript written by MBartlett called BooleanPlus. Works really well and very clever. Click on the + custom feature at the top to add it.
    https://cad.onshape.com/documents/84d939daceef6a928b8abcba/w/9e0dafb21fbe2ec8b983bbdc/e/7c5dcdb503f7e2f6ddba9d30
