Insert into Drawings
brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
Could anyone give a little advice please. I would like to insert  part of an assembly into a drawing at a stage prior to its completion to help in its construction. I have tried hiding certain parts in the  the part studio (Constructed top down )  however when inserted into a drawing this I still see the assembly with the hidden parts I have thought about  exporting the file then importing back as I would for exploding then deleting the parts as required, but would this effect the original part studio. Any help would be appreciated thanks  Regards Brian.
    @brian_pinder662 - now you're totally screwed because you will have to actually read the help! :):):)
    https://learn.onshape.com/learn/dashboard?labels=["Knowledge Base"]&values=["Technical Briefings"]
    Philip Thomas - Onshape
    Exactly the same technique for exploded views on a drawing . . .
  • brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
    Thank you for pointing me in the right direction. Could you also help with another problem, how to insert a part that has been modeld top down in a part studio, in the correct orientation to be dimensioned . at the moment  they are in their 3D positions. (Still Learning but getting there) Brian
    Should Philip be AFK allow me to jump in...
    You'll need to set up a "named view" in the part studio, and then you can use that in the drawing.
    Cheers,
    Owen S.
    HWM-Water Ltd
    Owen - you got it!
    Named view.
    Dead easy :)
