Extrude remove query
kiarian_coohill
Member Posts: 16 EDU
in Drawings
Fundamentals 3: Part Design Using Part Studios. 04 Exercise: Wheel Rim
I've been stuck on this for the past day. No matter what I do, I cannot get the extrude correctly as per the example. I'm also having to suppress extrudes to select the extrudes mentioned on the example, as when I try to select the face of the main sketch, the extrudes seem to have a priority over the sketch and it won't allow me to select them..
I need to know how I can select faces on the main sketch with the extrudes showing, and also how to complete this extrude remove command (see pic)
Lastly, why is there no 'maximise window' option for the tutorial window? You can maximise the intro video, why not the exercise tiles? Or am I missing something?
The main difference I see between your dialog box and the example dialog box is to select the "Face of Main Sketch" and not the whole sketch. Also, make sure that the the "Up To Faces" are selecting each side and not the same side, but I think its already that way.
You can always hover the mouse over the red text of the feature name and it can give you a tooltip to understand why it failed. i.e. hover the mouse over "Extrude 5" at the top of the dialog box.
A video tutorial with the more in-depth features of Onshape would be much better when they complexity ramps up. A still screen, not even showing the tool bar to the left is too little information. Oh well.
Edit: Scrub that. Back to square one. I have now re-done the entire model, can someone explain to me why the 'Face of Main Sketch' is not remove extruding to the 'Face of Extrude 1' with an offset of 20mm?!? See pic attached.
IR for AS/NZS 1100
If you hover your mouse over the red 'Extrude 5' at the top of the feature dialog (or over the red 'Extrude 5' in the feature list), you will see an error message detailing the reason why your feature is failing.
