Trying to resolve moving part to origin and getting dimension corrected
mark_cunninghammark_cunningham Member Posts: 78 ✭✭
https://cad.onshape.com/documents/44699c98d068c4be0bb65f64/w/d84b36fe31f2814409395efc/e/31a850d263af9797e8d0e317 So i'm still very new at this and i'm trying to get these dimensions into the front/face of this part. from the radius back needs to be solid with the secondary line shelved over over hung to accept a pin head with a shaft. the pin head will stop under the shelf. the tapered lines gradually  tighten up on the pin head until it stops when sliding the part down the channel. any help is good help! Thanks so much!
  • mark_cunninghammark_cunningham Member Posts: 78 ✭✭
    it is 18.81 mm to the radius with a step down thickness of 1.89mm which is half the channel thickness from land to surface. the other half continues 21.80 is a cavity an is where the pin head stops.
    Sounds good!
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,055 PRO
    I'm confused what you are trying to do. Can you draw the pin in position? Or sketch on a piece of paper and take a photo.
    Personally I'd model the pin head as a separate solid and then "boolean subtract" it from your part.
    Owen S.
    HWM-Water Ltd
    Sounds good!
