Importing a DXF into sketch "Selected file contains too many entities to import."
jose_veirasjose_veiras Member Posts: 2
Hi:
I Have a huge 36MB plan that was converted from PDF to DXF using Print2CAD, the file seems ok as in can be imported into Onshape using Import file instead of creating a new document, after importing the file I can view it using ARES Kudos.
But If I try to create a new document, create a sketch, select plane, insert dfx, the file is also imported but when I click it to be added to the sketch it shows a message "Selected file contains too many entities to import."
When I import the file directly, I can actually select any part of it but I'm unable to copy the part to a sketch.
I'm using the free version of Onshape
Any advice will be appreciated
Thanks
Jose
    36MB? It must be huge. Are you trying to convert the whole thing to 3D?
    A sketch can only contain a certain number of entities (I don't know how many). So if you only want to extrude the walls of this floorplan (I am assuming it is a floorplan), you could do this:
    1. Create an Onshape Drawing of the DXF
    2. Delete unnecessary details (like chairs and desks)
    3. Export the Drawing as DXF
    4. Reimport
    5. Import into sketch
    6. Repeat process for other areas of the DXF you want to import
    For the curious, the entity limit for bringing a DXF into a sketch is 8000 entities.  A sketch with 8000 entities, though, will put lots of unnecessary strain on the system and cause performance problems.  It's best here to follow Neil's advice and keep the import to as few representative entities as possible.
  • rodrigo_figueiredorodrigo_figueiredo Member Posts: 5
    i got same problem i solved it using png to and many part studio
  • luc_vander_puttenluc_vander_putten Member Posts: 2
    Can you please expand on your solution with some details?
