Feature dialogue box disappeared!
ben_isakovben_isakov Member Posts: 1
Hi all, just noticed that the dialog boxes (used to be on the bottom right corner) of a features aren't show anymore. How can I return them?
  • Jake_RosenfeldJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
    Hi @ben_isakov !
    I'm not sure exactly what you're talking about, what was the function of the box you're looking for?
    If you're looking to open a feature dialog for a specific feature, you can double click on it in the feature list (or right click and click 'edit').
  • maxime_coupeaudmaxime_coupeaud Member Posts: 2 EDU
    I have maybe the same issue. Even the sketch tool's icon is selected (here is the linear pattern) no feature dialog is visible. How can I fix that for my sketch?
  • _anton_anton Member, Onshape Employees Posts: 456
    @maxime_coupeaud, sketch linear pattern is different from the linear pattern feature (which you can access when you're not in a sketch) and doesn't come with a dialog. You interact with the sketch linear pattern by changing sketch constraints. That said, it's best practice to use the linear pattern feature if possible.
