Some of the folder and folder documents is missing
sai_atisai_ati Member Posts: 11 PRO
Some of the documents found missing from last 2 weeks.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    It is highly unlikely that the Document is missing. Try using the Search. If, however, a folder was deleted, it will also delete the contents. Please check your Trash.
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 418 image
    Hi @saad_nasser. I see from the server logs that you trashed 18 documents between 18 Jan and 1 Feb. @NeilCooke's suggestion for checking your trash is a good one. Remember that documents left in the trash for 30 days will automatically be deleted. Please open a support ticket if you are still having issues finding your documents.
    John Rousseau / VP, Technical Operations / Onshape Inc.
  • sai_atisai_ati Member Posts: 11 PRO
    I checked the trash. Even that folder is not there. Folder name starts with Pallet
    How to open a support ticket. Issue is still there/.
    @saad_nasser
    From your documents page or from inside a document, press the '?' in the top right corner, and then press 'Feedback' and describe the issue you're having.
