Hollow pyramid: How to construct with defined wall thickness
wolfgang_maierwolfgang_maier Member Posts: 39 ✭✭✭
Hello,
i constructed a 4 sided pyramid with a rectangle and a loft.
I cannot imagine howto create a hollow object with 5 walls out of the pyramide with defined wall thickness.
Any idea?
  • michael_mcclainmichael_mcclain Member Posts: 198 PRO
    I think you are looking for the shell feature:
    https://www.onshape.com/videos/shell-and-draft
  • HakroHakro Member Posts: 67 ✭✭✭
    I did it this way:
    Create pyramid > Shell >  (x) Hollow  > Select Part
    See picture 1 & 2.
  • HouseOfBreadCrumbsHouseOfBreadCrumbs Member Posts: 20
    I can find neither pyramid nor shell. Is this still possible with today's version (Oct 19th, 2019 | 1.104.24384.815574cc05b7)?
    There is no pyramid feature, you have to sketch a rectangle and a point and use Loft. Shell is there if you look for it (or use the command search).
