Entities selection priority
konstantin_shiriazdanov
Recently i notices that some of my FS and standart features suddenly started to only allow Entities of body type if the input field filter has this option among other entity types like faces. This is exactly not how it worked before, and i liked prevous behavior better. Was this intentional global change or it only with me?
  • Evan
    Evan Onshape Employees Posts: 68 image
    This was intentional change that was introduced in an effort to improve the selection experience around the split feature.  However, there have been enough adversely affected features in other areas that we will be reverting to the old behavior in the next release.
    In the meantime, you can use the "Select other" command to select individual entities.
  • MBartlett21
    When will the next release come?
    IR for AS/NZS 1100
  • Jake_Rosenfeld
    @mbartlett21
    Releases come approximately every three weeks.
  • MBartlett21
    @Jake_Rosenfeld
    That will mean I can remove some selection boxes in my feature here.
    IR for AS/NZS 1100
  • michał_1
    michał_1 Member, Developers Posts: 215 ✭✭✭
    That seems to affect also picking an edge in loft (when lofting surfaces)... akward
  • michał_1
  • konstantin_shiriazdanov
    it works so for all bodies - solid, sheet or wire. entities of body type got the highest priority. possibly priority control could be based on filter order and thus it could be adjusted transparently for each feature, instead of this hidden magic
  • michał_1
    Now you need to be a jedi to make Onshape work.
  • mahir
    Pick body or do not pick body. There is no edge.
  • MBartlett21
    This should probably be configured in a UIHint:
    what i think the code should look like:
    annotation { "Name" : "Example Query", "Filter" : EntityType.FACE && EntityType.BODY, "UIHint" : "PRIORITY_USING_FILTER" }
    definition.exampleQuery is Query;
    IR for AS/NZS 1100
  • kevin_o_toole_1
    @mbartlett21 We agree.
    For the upcoming release, we are simply reverting back to the old behavior for all custom features, so the issues described here will be fixed. However, if/when we want FS writers to control this, we'll use an explicit UIHint rather than implicitly encoding the priority via filter order.
  • Jake_Rosenfeld
    This should be fixed now :)
