extrude remove curvature sections
in General
I know how to extrude remove a flat plan section but having trouble with doing this with curvatures. https://cad.onshape.com/documents/d342db64fcfbc4a6b66817cb/w/9fe7d0846683a35027153c6d/e/34f7becefa6345126537ae2c
You should be able to see what I'm after here now. take a look at the jpegs in the task bar below. I believe what needs to be done is revolve remove to make a relief cut. I'm not sure how to do that on a curve.
