How to modeling M8 thread
karsten_hjort_gregersenkarsten_hjort_gregersen Member Posts: 15 ✭✭
Hi
I am a beginner in the free onshape. I hope somebody can assist me to lean how to modelling threads e.g. M6 or 3/8" threads?
BR
Karsten
  • karsten_hjort_gregersenkarsten_hjort_gregersen Member Posts: 15 ✭✭
    Please help
    Hi @karsten_hjort_gregersen
    Usually we discourage making threads as they will noticeably decrease the performance of your part studio, and aren't really required for design.  If you're trying to do this for 3d printing or something where the threads are actually required, you can try using this custom feature:
    https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/w/4693805578a72f40ebfb4ea3/e/f8aea9e5c33e02eab0854a4f
    If you've never used a custom feature before, check out these resources about how to add them to your toolbar and use them:
    https://www.onshape.com/featurescript (Watch the video in the 'Start using custom features' section).
    https://cad.onshape.com/help/Content/customfeature.htm
    @Jake_Rosenfeld
    How does that custom feature actually create the threads??
    The FS imports stuff from another document that is not public and gives no clue to how it makes the threads.
    IR for AS/NZS 1100
    @mbartlett21
    This is not an internal Custom Feature.
    @dave_cowden wrote it and may choose to answer if he wants.
  • dave_cowdendave_cowden Member, Developers Posts: 484 ✭✭✭
    Hi there @Jake_Rosenfeld
    Creating threads is not trivial, despite the apparent simplicity. As others have posted, actually modelling threads is typically only useful in special cases. One example is when making threads for 3d printing
    The general process is:
    Start with a cylinder
    Make a helix
    Make a sketch, which you use to cut the threads. For normal threads this is a triangle, but for other forms it is different.
    Sweep the sketch along the helix to cut the threads
    The complexities come in when you consider these things (in combination too)
    Standard thread dimensions
    Tolerancing. (Are you creating a nominal or realistic thread fit, and if so what thread fit)
    Lead in and lead out
    Multiple thread profiles
    Multiple starts
    Internal and external
    Performance. There are a lot of tricks to get performance to be food. As an example, in my feature I actually don't do a cut sweep in one operation, I make the thread form then subtract it from the original instead.
    Hope that helps!
    IR for AS/NZS 1100
