Ok, what is happening
David_LaPointDavid_LaPoint Member Posts: 10
edited March 2018 in Drawings
You know, I just don't understand why this program can't do simple math.  240+120+120+180+180+180+180+240=1440, right??? Well apparently not, because for 3 hours I've been trying to convince this program to accept simple rectangles fitting into another rectangle. I mean come on, i think your program is WAY too picky when it comes to this kinda stuff.  why does it take three hours to get nowhere with your program. I've spent a total of over 200 on it and I can't put rectangles into other rectangles without them breaking. thats dumb
https://cad.onshape.com/documents/6e19c49a358673dc32259c23/w/76595a084954b0d180c0e68a/e/0de80314c59f121722fb5554
    @David_LaPoint there is a lot going on in this sketch. You have equal constraints and dimensions that are conflicting. Try removing some of them.
    @David_LaPoint
    OS is doing a pretty good job in showing that there are problems.  You have driving (black) , driven (grey) and conflicting (red) dimensions going on there.
    Similar deal on the lines.  Constrained (black), unconstrained (blue) and conflicting (red).
    As you say its a simple sketch so the good news is once you're up to speed that'll only take a few minutes tops to draw.
    Shout if you have questions :)
    Cheers,
    Owen S.
    HWM-Water Ltd
