F11 -- I had no idea.
Tony_C_Tony_C_ Member Posts: 280 PRO
On accident the other day I hit F11 on my keyboard and I got more screen.
Had no idea that made the browser full screen.
Can't use your tabs, but you do get more viewing area.
    Nice find @Tony_C_ !
    Usually in this full screen mode if you push your mouse to the top of the screen and hold it there for a bit your tabs will slide in from the top.
  • Tony_C_Tony_C_ Member Posts: 280 PRO
    edited March 2018
    Ctrl+1 through Ctrl+8         Switch to the tab at the specified position number. The number you press represents the position of the tab on the tab strip.
    Ctrl+9         Switch to the last tab
    Ctrl+Tab or Ctrl+PgDown         Switch to the next tab
    Ctrl+Shift+Tab or Ctrl+PgUp         Switch to the previous tab
    Ctrl+W or Ctrl+F4         Close current tab
    Ctrl+1 or 2 or etc.   Switch to that tab.  Someone suggested keeping the Onshape Doc page on tab 1 - then it is always available.
    www.accuratepattern.com
    @brucebartlett
    I did not know about tip #10. It is really useful
    IR for AS/NZS 1100
