I can't see the chamfer command in sketch environment. Is there anything that can replace it ?
phamtomlanguephamtomlangue Member Posts: 2 EDU
edited March 2018 in Community Support
Hi!! I want to find chamfer command to help my work easier, but  i can't see it
    There is no chamfer sketch command.  Generally it is best practice to add fillets and chamfers later on solids.
    www.accuratepattern.com
  • phamtomlanguephamtomlangue Member Posts: 2 EDU
    Thank you :smiley:
  • emmett_weeksemmett_weeks Onshape Employees Posts: 29 image
    To add onto this, the sketcher only knows about geometry and constraints, so it doesn't really have any knowledge of what fillets or chamfers are, so when the sketch fillet tool is used, it creates a dumb arc with tangent constraints. This means that if there are upstream features change, that arc might update in a way that a fillet would not since sketch arcs can turn 'inside out' while fillets cannot.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,088 PRO
    Fastest way I see is just sketch a long line through the corner, then press "m" and trim the line segments.
  • rod_muirhead943rod_muirhead943 Member Posts: 96 EDU
    I miss several sketch features from Inventor in Onshape.
  • parviz_aghayarov072parviz_aghayarov072 Member Posts: 7 EDU
    hi guys bets method for chamfer use offset and x combination)
Howdy, Stranger!
