Bridging curve and beams
leo_timmermans
Member Posts: 8 ✭
Is it possible to use the beams feature with bridging curves. I tried but failed ...
Tkx for any clue
Leo
Tkx for any clue
Leo
I purposefully blocked the use of splines (lines and arcs only) because controlling the orientation of the profile during the sweep operation was problematic. If your bridging curve is attached to lines or arcs at the ends you could create a beam on those entities then use the face of the beam as your profile in a sweep feature.Senior Director, Technical Services, EMEA5
Thank you for your swift answer !
@NeilCooke
Your answer makes sense, but would it be possible to enable it on pipes/rods which don't need a profile orientation?0
