Options for photo quality video renderings of animations?
andrew_jorgensen202
Member Posts: 12 ✭✭
I understand the options for doing photo quality renders of stills. But I'm looking to nail down my workflow for creating photo quality animations of my Onshape models. Any of the rendering apps for Onshape that can handle photo quality animations?
1
3dcad
Member, OS Professional, Mentor Posts: 2,477 PRO
I use keyshot together with Onshape, importing/updating models is easy but connector should be updated for document tags, document folders, tab folders and configurations..
For rendering say 30sec HD animation at 30FPS, you need to render 900 images at 1920x1080 - that can be pretty time consuming depending on equipment. I would suggest to try with low resolution and low fps to get everything right, then use some render farm for creating the actual output.
I have no experience on OneRender animations, other than that it didn't support creating custom materials and for that reason I continued with Keyhot.//rami5
This of course is in the App Store.
CAD Engineering Manager
