How do you cut a shape into a solid form?
aaron_mooneyaaron_mooney Member Posts: 2
Dear Community - Note I am a newbee!
I have a shape that I have spun from a simple shape.
I have cut a hole down through the drawing - now I need to cut a shape into the top of the spun shape.
I have drawn the outline on the top plane but can't find a tool to allow me to cut down 3mm
I am used to solidworks where I can define the surface and then add a cut (emboss) - but not on onshape
Next I will be asking about how to cut a M20 thread!!
many thanks
Aaron
    Welcome.
    It's always helpful if you can post a link to the document and a sketch of the result you're after.  From the description above it sounds like you just need a blind extrude, but it can't be that simple, so I assume I'm not understanding the question!
    Cheers,
    Owen S.
    HWM-Water Ltd
    edited April 2018
    Hi @aaron_mooney
    Onshape does not have separate tools for additive and subtractive extrusions.  Simply use the 'Extrude' feature with the 'Remove' option selected at the top!
    https://cad.onshape.com/help/Content/extrude.htm
    @aaron_mooney
    and you may want to use 'up to face' with an offset.  there are a lot of options in the extrude command
    www.accuratepattern.com
