I would like know.Is there remember last time function?Is there have parameter function?
dragon_chen_dragondragon_chen_dragon Member Posts: 22 ✭✭
    Hi @dragon_chen_dragon
    There is no functionality in Onshape that can show previously used values for a specific parameter.  If you would like to see this as a general tool, or as the default for a specific feature, please open an Improvement Request from the Improvement Requests section of this forum.
    @dragon_chen_dragon
    There is parameter function, in Onshape they are called variables. Hit (x) to add new variable then write #variable_name to dimension dialog.
    https://cad.onshape.com/help/#variable.htm
    //rami
