Curves on faces
mark_cunninghammark_cunningham Member Posts: 78 ✭✭
edited April 2018 in General
  • mark_cunninghammark_cunningham Member Posts: 78 ✭✭
    left curved piece is 58.75mm long at top, 54.60 at bottom. 2.50mm thick. 8.07mm wide. Nubs are 1.50mm square, and 20.63mm in from top length to furthest nub edge on top of pic. bottom of pic is the other nub 20.23mm in to furthest edge on nub. these nubs snap into a cars air vent cavity. right piece is same thickness but 54.55mm long at top/51.20mm bottom 7.55mm wide. Upper nub is 3.08mm down from top, 12.80mm down to furthest edge. lower nub 12.93mm in from bottom edge to furthest nub edge and 2.94mm down from top edge.
    The document just has the pictures.  Where do you want to add the curve? On which face?  Are you after help to create this complete part and looking for a starting point?
    I will probably need help creating the left/right ends.
