Feature script beams butt joint
bill_de_la_vega
Member Posts: 20 EDU
I created a beam profile for 1-5/8 inch Unistrut. I'm trying to trim the butt joints but no matter which direction I choose for the vertex of the butt joint, it does not seem to trim the beams correctly.
I tried using Boolean subtract, but that did not work either.
https://cad.onshape.com/documents/865c20a35eb4b7134ecbabb5/w/42b70eca336e90614e8b0cac/e/99e26040134305c6f34c80ba
How should it look? I think there is too much going on there for the beam algorithm to fathom out. You may have to create them in 2 separate beam features. However the rolled edge does not give you a face to trim up to. You may have to edit the profile to add a small flat face mid-way through the hem.Senior Director, Technical Services, EMEA0
I apologize I should have shown how it's supposed to go. I made an assembly showing this in the document.
I looked at the profile there is a small flat already there.0 -
I guess that you fixed it, but wouldn't they normally be a mitre joint anyway?bill_de_la_vega said:I apologize I should have shown how it's supposed to go. I made an assembly showing this in the document.
No, not in this case. The beams are called uni-strut and are designed to be held together with 90° clamps and hardware. They are not usually welded.bigrogf said:I guess that you fixed it, but wouldn't they normally be a mitre joint anyway?bill_de_la_vega said:I apologize I should have shown how it's supposed to go. I made an assembly showing this in the document.
