change the colour of lines to be able to export as dxf for laser cutter.
miguel_silva737
Member Posts: 7 EDU
in General
In our school students do a lot of designs (and learning cad with the process) that have to be cut on laser cutter.
The laser gets black for cutting and red for engraving. how can i set up different colors for different lines?
Many thanks
Many thanks
HWM-Water Ltd
@owen_sparks , You can do this using notepad to open the .dxf file and then following the steps mentioned in this thread: https://forum.onshape.com/discussion/21721/changing-line-color-of-exported-dxf
