How to use μ (micro sign)
lukasz_piziaklukasz_piziak Member Posts: 9 PRO
Hi,
Does anyone knows how to use 'μ' sign for e.g Ra16 μin value on text note?
Thanks
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,983 image
    This symbol is not included in the note symbol drop-down, but you can copy and paste it from elsewhere (like I just did from your symbol in this post!)
    If using windows then an µ can be had by holding the ALT key and typing 0181 on the num-pad.
    Cheers,
    Owen S.
    HWM-Water Ltd
  • abdaal_ahmed545abdaal_ahmed545 Member Posts: 2
    You can type the micro sign by using Unicode 00B5 and Alt-X keys in Microsoft Word.
    If you want to read all methods of how to use micro sign then click on the link.
    Thank you !
