What surface based software works best with Onshape?
burhop
Member Posts: 22 ✭✭
I want to create some surfaces that are beyond the capability of Onshape (so far
) but I still want to use Onshape for most of the mechanical CAD work.
Is anyone using any free or low cost software that can create Onshape (e.g Parasolid) compatible surfaces? Yes, I know Rhino is great but I can't afford that as this is just a maker project.
Ultimately, I'd be doing a split face or replace face with the geometry in Onshape.
Best from cheap:
http://moi3d.com/ just 295 USD
example:
by lyes.
MoI is not capable of creating a-class surfaces, but still is powerful. It shares same engine as Rhino.
If you really short on budget, then try ViaCAD only 99 USD:
http://www.punchcad.com/p-27-viacad-2d3d-v9.aspx
5 -
Recently came across this one, not sure if it will work for what you need, but looks interesting:
http://cyborg3d.com/index.html
CAD Engineering Manager5
What can you do in Blender? I think this free, uses open cascade. That all I know0
I will have second the Blender suggestion. It is in fact free and there is no fee to pay if you make money off of your designs. It is a VERY capable program though it has a learning cure and most function are accessed via keyboard shortcut. I have had much success in using blender.
I think the question is this: does Blender (or some other free software) produce high quality surfaces in Parasolid format?0
Best from cheap:
example:
by lyes.
5 -
Yes. I think you are right. Has anyone imported Blender surfaces into OnShape?andrew_troup said:I think the question is this: does Blender (or some other free software) produce high quality surfaces in Parasolid format?0 -
Problem with Blender is that it's no cad software by any meanings. You can work with nurbs surfaces but as a result you get a mesh only, like this one:burhop said:
I don't now way to get a nurbs from Blender.0 -
CAD Engineering Manager5 -
That does look interesting. Unfortunately, it is not released yet. I did ask to join the beta.adrian_velazquez said:Recently came across this one, not sure if it will work for what you need, but looks interesting:
http://cyborg3d.com/index.html0 -
Integrityware are the people behind Power Surfacing for SolidWorks, and a lot of add ons. No doubt they are talking to everyone, other than Autodesk!0
