Change dirction of bends in flat pattern
bryan_lagrange
Member, User Group Leader Posts: 959 ✭✭✭✭✭
in General
@lana, @scott_harris I had an idea to have the flat pattern in the drawing be placed in the drawing with direction you need.
Onshape automatically creates a flat pattern. If a Direction column were added to the bend chart you could see how the flat patten in oriented. If the chart has the direction as up and you need it to have the direction as down (material finish reasons) You could toggle the view cube to bottom then right click and have a command such as set as default. Default would be the view you need the flat to be represented in the drawing. When changing the orientation and setting the new default, the chart would change from up to down or down to up depending on what you had previous.
Something like this:
The other option I would like to see added is the ability to change the angle callout from outside(default) to inside. I need the inside call out for press brake purposes. Sorry for the wierd angles, I did a quick sketch and extrude to create these screen shots.
What do you guys think?
Thank you for all your help
Bryan Lagrange
Bryan Lagrange
One other request I have is the ability to be able to reorder the bends to the sequence which would be used by the operator and even have backstop settings based on these sequences.
Twitter: @onshapetricks & @babart1977
Thank you for your suggestion.I'll give it more thought.
@brucebartlett
The "move up", "move down" options in context menu are there to allow reordering :
Twitter: @BryanLAGdesign
Thank you for checking in. Thoughts and suggestions - yes, not enough cycles to get to implementations - alas! If you have any additional thoughts, please voice them.
Thanks!
Thank you.
Thank you for your patience. Please keep popping this up.
So I definitely throw in my plus one for the ability to switch from outside angle to inside angle (supplementary to complementary)
Thanks,
Bruns
This will be very helpful for friends who are used to using sheet metal for the bending process, as it minimizes errors during the bending process, while manual editing in other 2D software will also waste time.
I hope this feature will be implemented soon.
