Loft no the Ipad
ivonei_andrade737ivonei_andrade737 Member Posts: 3
I'm using onshape on ipad, when I try to use loft command nothing happens.
if I use the same profile on the computer it works perfectly.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,971 image
    Hi - the UI interaction on mobile is different.
    Click Profiles on the dialog, then “add profile”. Click one of your sketches then press the back button on the UI. Then repeat for the second profile.
  • ivonei_andrade737ivonei_andrade737 Member Posts: 3
    Thank you very much, it worked perfectly.
