Failed to create line rendering of topology
ben_partouchben_partouch Member, csevp Posts: 158 PRO
Hey, I'm trying to create drawings for a model and getting this error:
What it that and how to solve it?
Thanks
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,040 PRO
    Can you link your document? Hard to tell without looking at the model
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 568 image
    We solved the issue Ben was having through our feedback/ticketing mechanism.
  • david_scott949david_scott949 Member Posts: 15 ✭✭
    Hi,
    I have exactly the same problem.   I want to create a drawing of an imported STL file but I get the same "failed to create line rendering of topology" message.
    After importing the file, it was floating far from the origine.  I thought that might be the problem, so I moved it back to the origin.  Unfortunately, no change.
    I've tried different drawing templates (ansi and Iso) but no joy there either.
    How can I get around this issue?   This is the file in question:
    https://cad.onshape.com/documents/80f78c0f5a035c39462fde8a/w/065d40c9233d20925a0f92dd/e/f6af8340ec48ae456ba56877
