Is this a correct DWG file?
cameron_shaw_dorancameron_shaw_doran Member Posts: 14
edited June 2018 in Drawings
I'm trying to export DWG file for waterjet
when I upload these to a site for quotes it grabs a bunch of stuff from the the sheet that it shouldn't be
its using  dimensions from the sheet rather than just the part
https://cad.onshape.com/documents/00151415211fdaae06332f67/w/f50f6a4e5b81957fcf610a58/e/1247c95158da170cc1d0da46
This is the file I'm trying to create a DWG from
https://cad.onshape.com/documents/389b8a0af7ce2cae3e1b09a7/w/8c6a5c4b902ac14192b4233c/e/2f73f05ae7f4310509fa5361
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,055 PRO
    edited June 2018
    File looks fine to me.
    What are you uploading it to? Some kind of automated quoting software?
    Onshape puts all the object lines on the "Visible" Layer. Try changing all the object lines to the "0" layer and see if it reads that.
    Assumption: The quoting software defaults to layer 0
