How can I prevent a chamfer to stop at an intersection and continue in the same shape?
robert_armin
robert_armin Member Posts: 10 ✭
Hi
Link to my Document:
https://cad.onshape.com/documents/56e41f74e4b07f79f46eae13/w/1281219028c78d58c7a85668/e/bfdb88454ea1921ea9c06e59
Tab Z-Axis
Team, I wanted to extend my chamfers along with the same profile as in the first picture but I cannot go across the intersection without chamfering everything? How can I achieve this?
Many Thanks,
Rob
  • owen_sparks
    Can you use a rib rather than a chamfer?
    Owen S.
    HWM-Water Ltd
  • robert_armin
    Hey Owen, yes you are right. But therefore I would have to create 3 Planes, 3 Sketches and a rib, wouldn't I? I was hoping there would be an easier way. Thx, Rob
  • emagdalenaC2i
    You can split the face and then use the Move face feature with the option to rotate
    Un saludo,
  • robert_armin
    thanks for your hint, what I wanted to achieve is lthe above. Currently this is done with rips as suggested earlier. Butt involves a 3 planes, 3 sketches, 3 rips. The example you showed above works out of the box with Chamfer. I wanted to break through the face with chamfer. Hopfully this explains it a bit better. Thx.
  • robert_armin
    ok, understood. Thanks for the all the answers! :smile:
