Onshape REST API using JavaScript
We are using the Onshape REST Api to extract data from Onshape.  We have this working using C# as well as Node.js, but I would like to do the same from client-side javascript.  Everything is in place using Ajax and I've verified all authorization headers are correct.  My problem is currently with the  "Date" header throwing the error: Refused to set unsafe header "Date".
Is this even possible or has anyone accomplished this?
Thanks for any help...
-Gary
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 668 image
    Can you give a little context why you want to use a Date header for a client request call?
    Jake Ramsley
  • awkawk Member, Onshape Employees, Developers Posts: 78 image
    The browser prevents javascript from setting a number of headers as a mechanism to stop forms of Cross Site Scripting and/or replay attacks from a compromised client. There is no work-around to avoid the browser if you're trying to set some header values from javascript in the browser.
    I'd echo Jake's point too - why do you need to set the Dates header on a REST API call? I can't think of any of our APIs that are particularly specific to the Date header. Furthermore we expect the REST API calls to be made from a server context and not directly from a browser.
    Director of API, Appstore, and App Partner Technical Support
  • gary_clough057gary_clough057 Member Posts: 7
    Thank you for your replies... Based on the sample code from GitHub demonstrating the usage of the API Key ( https://github.com/onshape-public/apikey ) I was under the impression it was required.  I tried removing it from the Node.js example and I got a 401 unathorized.  Here are the Headers that are working with the Node.js and C# implementations:
        headers['On-Nonce'] = onNonce;
        headers['Date'] = authDate;
        headers['Authorization'] = asign;
        headers['Accept'] = 'application/vnd.onshape.v1+json';
    Thanks again for the help.
