Onshape REST API using JavaScript
We are using the Onshape REST Api to extract data from Onshape. We have this working using C# as well as Node.js, but I would like to do the same from client-side javascript. Everything is in place using Ajax and I've verified all authorization headers are correct. My problem is currently with the "Date" header throwing the error: Refused to set unsafe header "Date".
Is this even possible or has anyone accomplished this?
Thanks for any help...
-Gary
-Gary
I'd echo Jake's point too - why do you need to set the Dates header on a REST API call? I can't think of any of our APIs that are particularly specific to the Date header. Furthermore we expect the REST API calls to be made from a server context and not directly from a browser.
Thanks again for the help.
