How do I add a point to a drawing?
chrisjh777chrisjh777 Member Posts: 209 ✭✭✭✭
I am trying to add a point to a drawing to indicate a Datum for CNC milling (Similar to a virtual sharp). I can add lines, centrelines, circle centrelines, but not an individual point.
What I am trying to do is indicate accurately on the drawing the precise location of the XY Datum (as crudely shown in my drawing below).  What I have done in SW is to extend lines (horizontal and vertical) until they intersect, than trim (if necessary) the lines back to a pseudo virtual sharp.
Document link here: https://cad.onshape.com/documents/d0068ecf012879ac6c71c310/w/3a6118e9c448d24e9cb089ba/e/8097d798b3671eb306cc1d7a
    You can now show sketches in drawing views - right click your view and select show/hide sketches (you need a sketch with a point in your part studio obviously).
  • chrisjh777chrisjh777 Member Posts: 209 ✭✭✭✭
    Thanks Neil,  Understood.  I created an XY Datum Point Sketch in the part studio.
    However when I try to insert the XY Datum Sketch into my drawing, I get a message "Failed to resolve sketch".
    edited July 2018
    @chrisjh777 that sounds like a bug. You can sketch a small circle or crosshairs and it will work.
    EDIT: points are not supported in drawing views because everything in a drawing must have a defined scale (a point is "infinitely small" so there is no way to determine how big the point should be displayed). Use a small circle.
    @NeilCooke Thanks. Now makes sense.  I changed the XY Datum Sketch to include a small (0.5mm) circle concentric with my point.
    I now have an accurately defined "Point" :)
