Draft issues on letter fonts
aaron_skidmoreaaron_skidmore Member Posts: 34 ✭✭
I often want to draft raised font letters, draft doesnt work for many curves in letters, of will only work at small draft angles - i don't want to modify individual geometry of trouble letters
https://cad.onshape.com/documents/47958b63ef67ca3213ffe546/w/2376e389eb9884f3f1db64cb/e/c88f3f5b0a67cb02ec5ee1f2
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,950 image
    If you select all the faces it is more likely to draft - I got 10 degrees out of it
  • AustinPackardAustinPackard Member Posts: 7 ✭✭
    Does anyone know if there are fonts that are more optimal for adding a draft?
