normal to plane / surface
jon_loschkejon_loschke Member Posts: 32 ✭✭
I so often find myself needing the normal to a plane, I'm surprised it's not a built in feature.  Other CAD has this.  If I'm blind, please point it out!
Before I go off and write a featureScript to do this, I want to see if there is a better way to do things.  Here is an example:
I need to square up a part to a plane (for some reason a context update caused it to drift from the reference).  This is for export, not assembly.
My simple thought is create two normals, one from part plane, one from reference.  Then I know angle (between normals) for rotation.  But I need axis for rotation, so I need a construct plane from the two normal vectors and then get the normal to that plane for the axis.  I did this and it worked perfectly.  Except I needed 5 sketches and 3 planes.  I needed 3 normals in that solution.  Is there a better solution?
Even if that can be done simpler, I still often need normals.  Am I out of the norm here?  (pun intended)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,990 image
    Transform with mate connector?
    Heck yeah, takes care of rotation as well as translation and no calcs needed :+1:
    OwS
    HWM-Water Ltd
  • jon_loschkejon_loschke Member Posts: 32 ✭✭
    Yes, thanks, that does work for the example I gave.  But I still often find myself doing constructions where it would be so much easier with a normal.  Imagine in my example that I needed that final line, not for a transform axis but some further piece of construction.  Can I create a mate and then use the Z axis as a reference line?
    So I'm not crazy.  Even you released a new feature that solves some of the exact cases (but not all) where I would have used a plane normal (if there were such a thing):
    MATE CONNECTOR AS AXIS
