Spline Point Stuck to Axis
famadorianfamadorian Member Posts: 390 ✭✭✭
If I draw a spline, then have its end or starting point attach to one of the axis, it gets stuck;)
I can't move it from there.
Is there some trick to "release" it from the axis' hold?
    @famadorian
    The end of your spline has a "horizontal" or "vertical" constraint to the origin.  If you hover over the endpoint that is "stuck" the constraint will show up as a horizontal or vertical line (respectively) within a blue box.  You can then click on this constraint and delete it with the delete key:
    https://cad.onshape.com/help/Content/constraints.htm
    You can also easily find this constraint by checking the "show constraints" box in the sketch dialog, then delete it the same way.
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    @famadorian
    Indeed; thank you, but I don't understand why it automatically puts a restraint on it, without me asking it to do it.
    Anway, thanks.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    @famadorian - most of the time it is useful, other times it is just plain annoying - holding down the SHIFT key while sketching will disable automatic constraints.
  • jules_nijstjules_nijst Member Posts: 12
    Using shift …I would have thought holding down the shift key when you do want to attacht the point, because then it is a willful act…
