Midpoint not showing
sam_onesam_one Member Posts: 19
edited February 2024 in Using Onshape
note: I am really really new to onshape
I am trying to place a line from the midpoint of a line section, like this:
notice the orange square?
well, when I try to do this elsewhere in my document, it doesn't show up, even though I am hovering where it SHOULD appear.
screenshot of the problem:
heres a link in case you need it beginner | Part Studio 1 (onshape.com)
UPDATE: this seems to be because in the first case, I am using a rectange, whereas in the second case it's just two lines, so there is technically not a line segment in between them, so onshape doesn't have any line segment to use the middle of.
Is this a bug, or is this intended behaviour? If the latter is the case, what should I have done differently to have this work with lines? I can't always use rectangles right
  • rick_randallrick_randall Member Posts: 411 ✭✭✭
    I believe you have answered the question yourself.
     In the 2nd example, only the mid-point of the entire line will show, not the line segment between points. As a workaround you could draw a construction line between the two points - and this will give you a usable mid-point snap. Or better yet, draw a line close to the mid-point (assuming you want a line) and use the symmetric constraint to force equal distance between lines.
    Hope this helps, good luck
  • sam_onesam_one Member Posts: 19
    Cool! I did answer my question myself, but I wasn't satisfied: it felt like it wasn't the intended way to do it, since it seemes a little cumbersome for such a basic operation.
    Your "better yet" solution seems real nice. I personally could have never thought of it because I didn't know you could constrain the "mirror" based on the "images", but it makes total sense now. It's the same thing as what I was doing with the symmetric constrain elsewhere, just the other way round.
    Thanks!
