Why does final Sliding Mate cause assembly to be overdefined?
roland_hauff
Member Posts: 6 ✭
I can drag the plunger and it animates properly but gives the error when I add the final sliding mate.
eric_pesty
Member Posts: 2,413 PRO
You have too many constraints stopping things from sliding "out of plane". Get rid of the limits on your cylindrical mates, and switch the first two to "revolue":
https://cad.onshape.com/documents/d27b8fdab628a00a7061b409/w/a6edc118892b03fe0a3c9de4/e/795f4a595e47c8399152a09f
eric_pesty
Yes you got it, the key is to avoid having multiple mates constraining the same things. You can "sometimes" get away with it when the result is the same (i.e. two things constraining in Z at exactly the same "depth" but it often causes issues as there is always some tolerance in computer math so best to avoid it.roland_hauff said:Ok, I think I get it. The main point is ONLY 1 rotary mate should limit motion in the Z direction. I tried making the first Revolute, and the last two Cylindrical with no limit in Z direction, and that works as well.Thanks #eric_pesty!1
