Suppressing assembly pattern part instances using configurations
David_Bower1David_Bower1 Member Posts: 11
edited February 2024 in Community Support
Hi,
I would really like to create assembly configurations that suppress chosen pattern part instances but i don't think it can be done?
  • S1monS1mon Member Posts: 3,298 PRO
    Depending on what the pattern is, there may be other options. Do you mean a pattern within a part studio (of features or faces), or an assembly pattern of instances?
    A screenshot and/or a public document would help us help you.
  • David_Bower1David_Bower1 Member Posts: 11
    I mean a pattern of parts in an assembly
    I have raised an IR for this
  • eric_pestyeric_pesty Member Posts: 2,158 PRO
    You are right, you can manually suppress instances of a pattern but it doesn't look like that state can be configured...
    Hopefully if they can add this they could also add the option to change the configuration of each patterned item, that would be very helpful...
