Mate connector not showing up in assembly?
I have a weird problem, and I can't tell if it's a bug, or user error. I had a part with a mate connector as the third feature. It shows up just fine in the part, but in the assembly, it doesn't show. The owner part of the MC is the part that I'm inserting. I just tried moving the MC feature to the end of the tree, and now it shows up in the assembly as expected.
The part goes through some split and boolean add features along the way. Is this MC behavior because of the part IDs? Is this expected behavior?
[I can't share the document publicly]
NeilCooke Moderator, Onshape Employees Posts: 5,873
There is a determinism issue with part IDs when there are lots of splits and booleans. We are investigating how to make it more robust, but for now it is what it is.Senior Director, Technical Services, EMEA3 -
eric_pesty Member Posts: 2,246 PRO
martin_kopplow said:Saw the same occasionally, thought I was stupid, but at least I'm not alone. This is highly annoying in complex assemblies and very unlogical (even if it could be explained by entity IDs changing after certain operations, but hey, if it can be easily explaned, it could as well be caught!) If a mate connector is linked to a feature (like in above example), the correct owner part could be calculated or forwared even after a split operation or the like has been made.1
Perhaps having split create two parts with the same name is confusing for the user (i.e. me), since it's not clear which one has actually kept the internal ID from prior to the split. If I had a clear indication which one had inherited the ID, I could be more careful about downstream features.
In this example I am not sure why you would need to define an explicit mate connector at the center of the hex when there is an implicit MC right there always available...
This toally solved the problem for me. As soon as I changed the owner in the mate connector feature to the part, it showed up in the assembly.
THANKS!!!
@S1mon Check the owner of the mate connector is set to one of the parts that show up in the assembly. If the parent is a plane or sketch then it wont show in the assembly.
This is an old thread. I can't remember what I did to solve this particular issue, but it's not a current problem for me.
