What does that mean ... QuotaExceededError: The quota has been exceeded.
  • Ste_WilsonSte_Wilson Member Posts: 465 EDU
    A little more context to when the error appears would probably help the more knowledgeable people here help you out.
  • otto_kaufmannotto_kaufmann Member Posts: 2
    The error appears when i try to load a document. what can i do against?
  • rick_randallrick_randall Member Posts: 396 ✭✭✭
    I have seen this (or something very similar) when I was trying to open multiple documents in rapid succession. It basically gives you a time out. Try giving a little more time between clicks and see if this makes it go away.
    A follow up, to the above statement - If you try to open multiple documents before the first one is finished loading (still spooling) - let the document finish opening, then open others.
