Onshape, Inc.
I too would use a wall thickness check. I'm sure it will become native functionality at some point (like draft analysis), but there might be a way to do it with featurescript as a stopgap. I can't really think of any efficient way to do it though. The best I've got offhand is to cut the model into tiny cubes based on your thickness threshold, then check if the volume of each section is bigger than it should be, but that would probably be buggy and take forever to compute.
To add the feature to your toolbar you can click the + Custom Features button and then click the feature in the list:
FeatureScript is currently not available in Assemblies.
https://thesmoothcut.com/
