Offset Sketch - switching offset direction
Urs_Egger_REACTUrs_Egger_REACT Member Posts: 119 PRO
Hello all,
I often struggle with the sketch offset feature. The offset starts in the wrong direction and if I switch direction the selection chain gets broken.
Is there a way I can switch offset direction and keep the chain selection active?
  • S1monS1mon Member Posts: 3,982 PRO
    Try smaller offsets first. There’s probably something twitchy in that curve that looks like a fillet. Check the curvature and the minimum radius.
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 474 PRO
    You can try to offset a complete chain by click and drag in a direction (holding the left mouse button down).
    But this will work only if the origin lines are not set to contstruction lines.
  • Tanja_HofmannTanja_Hofmann Member, Channel partner Posts: 13 EDU
    Hi there,
    can´t you just pull on the arrow to get the offset in the right direction?
    What are your original sketch elements? I tried it with splines, arcs and lines and had no problems.
  • Urs_Egger_REACTUrs_Egger_REACT Member Posts: 119 PRO
    Hi there,
    Thank you for your tipps. Seems like my origin sketch spline did not work because it was a "used" curve from a body edge. With standard curves your recommendation works.
    Urs
