how to add parts to a document
Hi all,
new to cad but going thought the training and learning a lot. using the free version.
one thing I am currently looking for for a small project i want to start is adding a part like a bearing, to a shaft that i design in OnShape. I know there is a concept of adding existing parts to your assembly like standard screws and bearing and other static components, but can't figure out how to actually do it.
Thanks
Thanks
GWS50 Member Posts: 446 PRO
Have a look at the McMaster-Carr website. There you will find many CAD parts that you can download and import into Onshape
https://www.mcmaster.com/
eric_pesty Member Posts: 2,126 PRO
nelson_pereira280 said:too bad onShape can't edit or convert a mesh to a solid for editing. thats what I wanted to do but instructions and videos are very scaresed.
However mesh models are inherently "imprecise" and if you want a bearing model, a STEP file downloaded from McMaster (or a number of other available sources) is a much better option.1 -
dirk_van_der_vaart Member Posts: 552 ✭✭✭
If you want Bearrings, then this is your source.
https://www.skf.com/group/support/engineering-tools/cad-information
For other types of content, just use Import , the plus sign in the lower left. Onshape will import:
