Extruding accordingly to given dimensions
Ф_А_С_TФ_А_С_T Member Posts: 2
Hey folks
I wondered if I can ignore or improve this:
I generated a spline for usage as the outmost dimension. Onshape seems not to use the precise spline but somewhat close to this. Is this lazy grafics, or too little information?
the image shows the discrepancy between sketched spline and outmost dimension of the resulted extrusion.
Has anybody faced this before and how was the process of improving the extrusion result?
Cheers
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,542 PRO
    Most likely just a display thing, try enabling "view in high quality" and see what that looks like...
