Make Angled Walls
cogster_bcogster_b Member Posts: 2
Alright so in the image here I have two sketches with highlighted parts. I want to connect these highlighted parts together with walls but whenever I make an extrude it won't let me have a different shape for a destination. How would I connect these?
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,060 ✭✭✭✭✭
    Use Loft.
    Note that you will have to first loft the whole profile (including internal faces), then loft-remove with the internal faces.
    Use Loft.
