I have lost an assembly .
mick_fairlessmick_fairless Member Posts: 5
I have lost an assembly. I can't find it anywhere , it is not in trash but all of the component parts still exist.  I worked on the assembly this morning and closed Onshape and reopened it this afternoon to find the assembly apparently missing.  Am I doing something stupid  and is there a way to retrieve that which I have apparentl lost?
  • S1monS1mon Member Posts: 4,043 PRO
    It's pretty hard to actually lose work. You should be able to look at the history and find a place before you deleted a tab or did something which would cause the assembly to go missing.
  • mick_fairlessmick_fairless Member Posts: 5
    Thank you for your reply Simon.  I have found the assembly after much searching.
