OnShape only utilizing 2% of Dedicated GPU
Peter_Stec
Member Posts: 5 ✭
in General
Hello all, I'm thinking I can't be the first with this problem! I have an RTX A2000 that scores wonderfully in OnShape speed testing, and shows usage when loading an OnShape model, but when I work on larger assemblies the dedicated graphics card doesn't pass 2% utilization...which is a shame due to my latency.
I fired up SolidWorks for a comparison, the same model had nearly zero latency and was utilizing up to 100% dedicated GPU performance.
I've can see Chrome and the card are playing together due to the high OnShape scoring at cad.onshape.com/check, and because the GPU is maybe 28% utilized when initially loading an OnShape model.
Please help my life be literally smoother!
https://cad.onshape.com/help/Content/webgl.htm
On my new laptop running Windows 11, I first attempted this same solution and saw no improvement. I then attempted setting it in the NVidia control panel. I received a message that said the toggling between dedicated and integrated is controlled by the operating system.
I then tried to adjust this in WIndows settings themselves:
1. I went to Settings, System > Display > Graphics,
2. then "Add an app",
3. selecting the Chrome executable at C:\Program Files\Google\Chrome\Application\chrome.exe,
4. then choosing "High performance".
Then my performance was as desired.
Not sure if the above matches your situation but thought I would share my solution.
I followed the web gl instructions previously, and it did activate my dedicated GPU (wasn't being used before I read your help file and implemented it's suggestions).
So any suggestion on how to get the dedicated GPU to be more dominant? I've tried disabling the integrated GPU and it didn't help, it actually made things worse.
I've previously set both Windows and Nvidia to 'High Performance' for Chrome which got the GPU up to 50% utilization while loading an assembly, but it's still super choppy.
