Newbie with question how to model a barbed tubing coupler
![chris_rose989](https://cad.onshape.com/images/placeholder-user.png)
in Drawings
I'm a real newbie with Onshape and CAD in general. I need to design a custom part that will couple two pieces of plastic tubing together where each piece has different inside diameters. I want to put barbs on the coupler to help retain the hose to the coupler, like this CCT1607B - Honeywell CCT1607B - 1/4" Barbed x 1/4" Barbed (brass) Plastic Tubing Coupling (supplyhouse.com)
I have no idea of how I should design this.
Can anyone provide me with some advice of how to start the model?
Thank you
Thank you
https://www.mcmaster.com/products/tube-fittings/tube-fittings~/
A good exercise to learn from. However, I would be tempted to download two established part models of the two different sizes and marry applicable elements of the downloaded sketches together.
= Scotty
Also have a look at the learning centre, which has excellent video instruction and is very well laid out.
https://learn.onshape.com/
https://cad.onshape.com/documents/e9da086fde530243dedd9c55/w/0a7b9a5093d7a077300f2616/e/3f5a318bd9f372ea1b1d1a31
