In an OnShape Drawing, is it possible to hide all Construction lines that are present in a Sketch
john_smith077john_smith077 Member Posts: 175 ✭✭✭
Hello
Is it possible to hide all construction lines when have made a Drawing from a Sketch?
Background
I am using a Sketch that I have created in OnShape to create a DXF file (for use in the free magnetic modelling software 'FEMM').  My problem is that I need to use Construction lines in order to create the Sketch. But I don't want those lines to appear in the DXF file.
Thanks
J
  • S1monS1mon Member Posts: 3,373 PRO
    I don’t know of a simple solution, but you can always create a second sketch which uses edges from a previous sketch - leaving out the construction lines, of course.
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 453 PRO
    @john_smith077
    You can set the color of the construction lines to white.
    But Onshape doesn't allow it to set it to a pure white, because this would not be visible on white paper.
    So just set it to almost white:
  • alec_stewart245alec_stewart245 Member Posts: 7 EDU
    How can I do that? [I tried copying and pasting a sketch but I couldn't see any way to anchor the pasted sketch so that all the lines go black. Apologies for newbie question!]
    Changing colour won't help me because I importing the line data in the .DXF file into another application.
    J
    “Use edge” with the entities you want to see.
  • Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 117 PRO
    Couldn't it be added to the 'show/hide' menu for sketch construction lines, in the same way you can show/hide sketch points?
  • Ste_WilsonSte_Wilson Member Posts: 477 EDU
    I think that would be a good shout. Have the option to remove individually I guess, but an on off toggle would be really usefull. Since the right click option of drawing from sketch I've had my students carefully removing borders around text!!
