In an OnShape Drawing, is it possible to hide all Construction lines that are present in a Sketch
john_smith077
Member Posts: 175 ✭✭✭
in Drawings
Hello
Is it possible to hide all construction lines when have made a Drawing from a Sketch?
Background
I am using a Sketch that I have created in OnShape to create a DXF file (for use in the free magnetic modelling software 'FEMM'). My problem is that I need to use Construction lines in order to create the Sketch. But I don't want those lines to appear in the DXF file.
Thanks
J
Background
Thanks
J
You can set the color of the construction lines to white.
But Onshape doesn't allow it to set it to a pure white, because this would not be visible on white paper.
So just set it to almost white:
Changing colour won't help me because I importing the line data in the .DXF file into another application.
J
Couldn't it be added to the 'show/hide' menu for sketch construction lines, in the same way you can show/hide sketch points?
I think that would be a good shout. Have the option to remove individually I guess, but an on off toggle would be really usefull. Since the right click option of drawing from sketch I've had my students carefully removing borders around text!!
