Offset from imported DXF sketch causes lines to break
ryan_hsu085ryan_hsu085 Member Posts: 2
Here is an image for reference. How do I prevent this? I was looking into constraining the DXF sketch but from my research, it does not seem possible.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,583 PRO
    You are probably better off not doing offset within the sketch. If you are going to extrude just do a thin extrude or extrude a surface and offset it.
  • S1monS1mon Member Posts: 4,043 PRO
    It also looks like what you imported is a bunch of lines instead of a curve. Is that what’s in the original file? If not, there may be export options to control if everything gets converted to poly lines.
